Best plunge router bit? http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=19887 |
Author: | Ricardo [ Wed Dec 03, 2008 5:00 pm ] |
Post subject: | Best plunge router bit? |
I burned up my upspiral 1/4" bit hogging out mahogany for a dovetail neck connection. I use my dovetail bit to do the final cuts. What do you guys recommend for a good router bit for the job?. |
Author: | Steve Saville [ Wed Dec 03, 2008 6:50 pm ] |
Post subject: | Re: Best plunge router bit? |
First, table saw as much as possible then use the router to finish the job. I use carbide endmills. Wood is often harder on tool bits than steel. |
Author: | Chas Freeborn [ Wed Dec 03, 2008 7:13 pm ] |
I waste out dovetail mortises with a 1/2" dia ocemco spiral bit with a plunge tip. I think that a 1/4" bit is a little skimpy for the job. -C |
Author: | Bob Garrish [ Wed Dec 03, 2008 9:46 pm ] |
The cost of router bits is actually insane compared to end mills now. It's funny, but I think it's mainly because it's mostly hobbiests buying router bits so they're not prone to shop around. Anyhow, buy carbide end mills unless you need a bearing on it. |
